You also have clearance issues on your '68 as to which booster will fit. The '72 and later units are too big around to fit on your firewall and still clear the engine block (big block) and any fender braces. You should probably use the 68-71 booster setup as it is sure to fit, be sure it is the disc brake unit so that you will have full operating pressure.
