What type of ATF to use in a standard?
Triple Pickle
USA
I have a 1971 Fury I with a 3 speed manual transmission. What type of ATF that is available these days is the best?
If you live in Alaska and drive it in the winter use ATF. I use this with good results.
Please do not use atf
1st choice is passon lube - yes he sells lube that works, well tested oer [sic] here, i never found anything better 2nd choice GL4 NOT GL5 gear oil
agreed, you need manual transmission gear oil not ATF(automatic transmission fluid)
Just saying…
when I removed the transmission ATF was pouring out the back…
how would the gears "rattle" at idle speed? what is "direct gear acceleration"? direct drive is third gear. input and output shafts are connected. that's when the transmission is least noisy.
Ma Mopars profound wisdom shall not be questioned in this forum!
The manual is outdated just like 160/80 thermostats and bias ply tires. ATF was recommended because people complained about cold sticky transmissions. ATF does not have the same lubrication characteristics of the proper [passon] lube. This is not alaska. The gear boxes work the best with the proper lube not ATF.
I’ll be using gear lube in the transmission and save the ATF (alcohol tobacco firearms) for myself since I’m also outdated!
Best answer.
I had a trans builder tell me years ago that a manual trans that takes ATF can be filled with engine oil. I have used 10w30 in GM T5 manuals, later GM manuals take synchromesh like Mike posted. I used to service a customers Honda Accord with a manual trans and it used 10w30. He wanted it changed with every engine oil change.
