Hey guys it's me again...about my '65 Imperial.
I had to install new front end wheel bearings. The pass side actually failed on me and welded itself to the spindle. After a good time cleaning that up, I had to get another hub/drum assembly from Murray park, as my hub was too badly damaged to hold a new bearing and race properly. The replacement i got from MP, though a perfect match to mine, wasn't as worn in the inside of the drum as mine was. Anyway I did notice that when I reassembled everything, installed the new bearings, and locked down the nut etc...that when I tried to spin the drum while torquing, it would not spin freely all the way.
My friend told me that it's not a problem w/ the new bearing, but that the new drum was rubbing against the brake shoe inside of the drum, and that the brakes would have to adjust to this new drum ...which obviously is not as worn down as my original. He said to drive it for short distances and maybe do some reverse braking to allow the self adjusting brakes to "adjust" to the replacement drum. He also said keep a check on the temps of the hub after driving. SO that's where I'm at now.
My question is the temps ...what's a normal range for the hub? I drove about 15 miles, up to speeds of 60. Aftewards I took the temp readings. I was getting readings of 129-135 on the drivers side hub, a little less at the lugs area. But on the pass side that had the damage and the replacement hub/drum assembly, I was getting 152 on the hub and you could feel that it was hotter than the other side. The lugs area measured the same as the lugs area on the drivers side. The Hub part was where it was hotter. IS this okay? Is it too hot for continued use? Should I expect this extra heat until the brake shoe there get adjusted to the drum? How long until that happens? OR is the fit so tight that the brake can't adust enough on it's own and I will have to go in manually and space out the spring and adjust the brakes shoes myself? I do have my original drum and if need be I can press out the good hub on the replacemnt and install it into my drum ... but the murray park drum is the same other than it's not as worn down inside. What to do? Don't want to damage anthing again after all this repair work . Thanks.
