Planning to do a refresh on my 73’ Imperial. Manual says 8.2 compression on the 440. Would a 906 head be an upgrade to bring the compression up to say 9.5 or is there another option/recommendations? Thanks.
906 and 452 heads are both open combustion chamber heads with same size valves-- if I remember correctly.Planning to do a refresh on my 73’ Imperial. Manual says 8.2 compression on the 440. Would a 906 head be an upgrade to bring the compression up to say 9.5 or is there another option/recommendations? Thanks.
Do you have a ballpark number for how much to shave the head, without shaving the intake side?Only enough so you can still bolt on the intake without any trouble.
This option sounds most reasonable and easiest on the pocketbook. Thank you.906 and 452 heads are both open combustion chamber heads with same size valves-- if I remember correctly.
The 906 do not have hardened valve seats if not already rebuilt.
So not gaining anything by doing this head swap.
You can do some research on either Eddy or Trick Flow aluminum heads maybe?
The low compression is from the pistons sitting lower down the deck height.
In a perfect world, swapping in zero deck height flat top pistons would be a way to bump compression.
But with today's corn fed gas pump....ping city. Not worth the expense as it will snowball into balancing the reciprocating assembly. Not cheap.
The cheap way out is shave the heads a little and deck the block a wee bit.
To get more Oomph I would recommend a nice RV cam, dual exhaust, recurve the distributor,fine tune the carburetor, port match everything and massage your existing heads for more flow.
Hope this helps.
At the risk of being pragmatic, you really sure you want to raise the compression?Planning to do a refresh on my 73’ Imperial. Manual says 8.2 compression on the 440. Would a 906 head be an upgrade to bring the compression up to say 9.5 or is there another option/recommendations? Thanks.
Weren't the 67 heads closed chambers? They would boost his compression some, but I think they came with smaller exhaust valves except for the high-performance versions. I would think the best way to raise compression is a piston change. He will need more octane then, which means more $$$.
Hi cbarge, this plan is perfect for what I would like to achieve. Opened a can of whoop-*** with this question, and my fault. Am assembling the bottom end of a 67" 440 and for some reason, had the 73' rebuild in my head. After sending the question I realized the lower piston position will be the problem in the 73' and like you and others have mentioned, will be an endless tail chasing to get what I thought was reasonable/possible (9-ish, yes CBODY67, 9.5 is probably too much). All good information however and thanks to everyone. Going to be doing some port and polishing on what ever I end up with however would like to get something different than the 345's that, according to my research, are in the 73'. What heads did you end up with in your 68'?915 heads as cores if found are not cheap.
Then you can easily blow 800 to 1k rebuilding them.
Not far off the price of new heads ready to run out of the box.
On my 68 Newport, I used .17 thou head gaskets and the heads were planed .10 thou and the deck was skimmed just to be perfectly striaght/flat.
My intake bolted on with no issues.
My CR is about 9.2 so I can run any gas necessary just to get home on long trips.
Big blocks like to breathe.
Anything you can do to make it breathe better will gain some torque and a few horses along the way.
It is amazing what a dremel tool and a few hours on your factory heads can do to improve flow.
My preference is 452 castings 9n older blocks with original pistons.Hi cbarge, this plan is perfect for what I would like to achieve. Opened a can of whoop-*** with this question, and my fault. Am assembling the bottom end of a 67" 440 and for some reason, had the 73' rebuild in my head. After sending the question I realized the lower piston position will be the problem in the 73' and like you and others have mentioned, will be an endless tail chasing to get what I thought was reasonable/possible (9-ish, yes CBODY67, 9.5 is probably too much). All good information however and thanks to everyone. Going to be doing some port and polishing on what ever I end up with however would like to get something different than the 345's that, according to my research, are in the 73'. What heads did you end up with in your 68'?
Just my 2-cents....Planning to do a refresh on my 73’ Imperial. Manual says 8.2 compression on the 440. Would a 906 head be an upgrade to bring the compression up to say 9.5 or is there another option/recommendations? Thanks.
