70Tom
OK, so I have most of the radio wired up. Couple questions:
1) The red wire should be connected to an Ignition switched circuit that is fused. Do I have it hooked to the correct wire in the harness (re with white stripe). Or is there a different wire I should be using. Gary reaffixed the original connector to the red wire, so that is the type of connect I'm looking for. And there was nothing under my dash hooked up to that red wire with the white stripe.
2) These yellow and red wires were cut for some reason. Any ideas to what they go to?
Thanks
Thanks
