Witch oil pan is right ?
mopar Joe 65
Tremonton, utah 84337
Could someone tell me if a 402 is the right pan for my 65 fury 383 ? I also have a 187 that come with my 68 383. I hope one of them will work ?
You need the 187 pan for clearance of the right side inner tie rod end. The 187 has a small raised recess on it's right side for the rod end to pass under. There are other pans on the market that use a slanted section of metal to provide this clearance but unless stated positively buying one is trial and error.
Thanks for the info, i plan to use the 187 pan but was wondering if you or someone knows which number pan came on a 65 fury 383 ? Also is that 187 a 4 quart pan ? If someone knows it would be helpfull thanks.
