commando1
Original 1963 Chrysler Newport 361 V8, Manual 3 speed on the floor
1963 Chrysler Newport 3-speed Big Block Stick Shift | eBay
1963 Newport 4-doors 3-speed floor shift. Big block 361 engine. Mostly original. Run, yard drive. Brake good. Easy swap to 4-speed, just need a A833 transmission, shifter, and might be bellhousing, everything else are there. It was original white and repainted to this color, I didnt really care about that when I bought, because the coolness just outweight such nonsense. Four-doors stick shift is rare, and cool. Poor man muscle.
Real man car, manual everything. Manual transmission, manual brake, manual steering. No stupid AC (you will thank it when playing with your toy, the heat AC-component adding to you much greater than such removing when cruising).
Currently have gas container in trunk, will need new gas tank or might be just tank cleaner. All frame are good, except passenger side front-extension have rust at the end (2nd from last photo). Floors good, trunk good. Rear doors handle was removed. Side view mirror removed, I do have one for 62 Chrysler (look in my other items), will go with the car. Most lights, gauges work except fuel gauge. Wipers work. Windshield has crack line, I do have a nice original replacement for it. Engine strong, a lot of torque, transmission shifts good. Clear title. Ask any question 703 853 0045.
