The pictured booster, plus the "dual" notation, would be a dual-diaphragm booster, which would be for power disc brakes.
Changing the lines and m/cyl to a '67 C-body item would be the easiest way out. The "balance block" probably refers to the block that triggers the "BRAKE" light when one axle-set of brakes might lose pressure? Not sure how to wire that in on your car, IF that's all it does.
The wiring is pretty simple, the parking brake switch lights the indicator bulb on the dash by supplying a ground. The brake warning does the same thing so just splice a 2-1 connector into that circuit and run a lead from the brake warning valve.. I probably would not use the booster in the ad, it is a Chinese knock off with a GM 2 bolt MC. It is also an 8" booster as opposed to the 9" used on C-Bodies. There was an 8" Bendix dual diaphragm booster that was used on the '64 Imperial that would be a better choice if one can be located and it should bolt to the 300 Chrysler mounts. Even though this booster was used with drum brakes, it would supply adequate braking power for discs.
