1966 Newport 383 — Factory Mechanical Fan & Spacer Part Numbers?
IHChris
NW
Hello all!
I recently acquired a 1966 Newport with the stock 383 2-barrel engine. The previous owner removed the factory mechanical fan and installed an aftermarket electric unit in front of the radiator.
I'd like to return to the factory setup if possible. I checked the factory service manual, and it states that my non-A/C model wouldn’t have had a fan shroud and originally came with an 18" 4-blade fan paired with a 1.72" spacer.
I’ve looked on eBay, but there seem to be quite a few variations of these fan blades, and I’m not sure how to find the correct factory part numbers.
Can someone please help me find the part numbers for the fan blade and the corresponding spacer?
Thank you!
-Chris
Found it! Looks like the bottom line in this section fits my car:
"w/383, 440 cu. in. Eng., W/O Air Cond.,
w/o Cleaner Air Pkg., w/o Trailer Tow Pkg., 4 Blade"
The part number appears to be 2265034.
Chris
For the fan spacer, the bottom line in this section fits my car: “w/o Air Cond.”
The part number appears to be 1851959.
Chris
EDIT #1: I may have spoken too soon. After searching around on the interwebs, it appears that this spacer is 1.060" thick. The factory service manual states that it’s supposed to be 1.72" thick. I’ll continue to look around.
EDIT #2: Okay, so I found a hardware kit on a Mopar parts website that shows the 1.720" thick spacer as part number 1674746. In the screenshot from the parts catalog, this part number is listed on line 3, which reads “w/A/Cond.”
Assuming the factory service manual is correct, I need a 1.72" spacer with part number of 1674746. If the parts catalog is correct, then I would need a 1.060" thick spacer with part number 1851959.
Thank you for confirming. Now I just need to figure out if that’s the correct one I need. The factory service manual states that I need the 1.72" spacer, which is part number 1674746. The factory parts book lists part number 1851959, which is 1.060" thick.
Chris
Note: The single asterisk in the attached image denotes “same as above.”
I’ve been poking around on the internet, and it appears that my car should have come with a 22" radiator from the factory. Currently, it has a 26" radiator.
The previous owner stated that he installed a new radiator not too long ago. Is there any way to determine whether this car came with a 26" radiator from the factory, or if he upgraded to this size?
I know the car didn’t have A/C from the factory, but perhaps it had the CAP or tow package. Would either of those have come with a 26" radiator?
Chris
Chris
Take a picture of the fender tag and post it here. There's enough guys that can decode it and maybe tell you what it originally had.
The other thing to look at is the opening for the radiator. If it looks like it's been opened up to fit the 26" radiator, there's your clue. Some guys have bolted radiators in without cutting the opening, so if the present radiator looks like it doesn't fit, that's another clue.
I may have the right spacer and possibly a fan. If I do, they will be the cost of shipping, but I have to look.
I agree with Big_John, "There's enough guys that can decode it and maybe tell you what it originally had". EVERYONE here will help. There is a wealth of knowledge and all of us "C-Body guys" like to share as well as absorb information.
Hey Big_John,
I don’t have a picture yet, but I did run the VIN through two different decoders. Both indicate that the car was originally a 4-barrel car. It makes me wonder why someone would pull the intake manifold and carb setup to convert it to a 2-barrel. Weird.
On the topic of the radiator, I took a closer look today and can tell that someone added the 26" radiator. The core support opening is for a 22". When they went to the 26", they used the original mounting holes on the driver’s side and added two new ones on the passenger side.
Now that I have a 26" radiator, I’m wondering if I should track down the corresponding shroud so I can run a 7-blade fan and clutch setup. I go to car shows a lot, so the added cooling would be a big plus. What do you guys think?
Chris
Do you think it is the original engine?
Chris
Not a bad idea....
FYI....
If another spacer size is needed, Chrysler made several sizes for different applications:
The following table lists Chrysler fan spacers:
Thickness (inches)Part NumberNotes
0.70
1851960
May be mis-marked as 1851959.
0.90
2265037
1.06
1851959
1.24
1825932
1.30
1851961
1.40
1730155
1.60
2120510
1.72
1674746
1.86
2863219
May be mis-marked as 2265036.
2.00
1825056
2.20
2265036
2.38
2120130
Note that a few spacers were mis-cast with the wrong part number. The spacers were made by Chrysler themselves and were cast at the Kokomo Casting Plant (KCP) in Kokomo, Indiana. This same plant also made the transmission housings, extension housings, alternator end shields, starter housings, and other cast aluminum parts.
Chrysler spacers made in 1964 and earlier were cast heavier than the later versions.
Several aftermarket spacers are also available, including Flex-a-Lite brand:
The pictured spacers are older products. These are bigger in diameter than the original Chrysler spacers. Flex-a-lite's newer offerings are not as heavily made.
The following table lists Flex-a-lite spacers, although some may no longer be made:
0.09375
501
Fiberglass
0.25
502
Aluminium
0.50
504
Aluminium
1.00
508
Aluminium
1.25
510
Aluminium
1.75
514
Aluminium
2.00
516
Aluminium
Not a bad idea....
No, unfortunately it’s not. The previous owner said the original block cracked and wasn’t repairable. He sourced a used block from a Super Bee and had it bored .030 over. He stated that everything from the previous engine was swapped over. He did replace the carburetor with a rebuilt unit a few years after the engine rebuild.
Chris
FYI....
0.70
1851960
0.90
2265037
1.06
1851959
1.24
1825932
1.30
1851961
1.40
1730155
1.60
2120510
1.72
1674746
1.86
2863219
2.00
1825056
2.20
2265036
2.38
2120130
0.09375
501
Fiberglass
0.25
502
Aluminium
0.50
504
Aluminium
1.00
508
Aluminium
1.25
510
Aluminium
1.75
514
Aluminium
2.00
516
Aluminium
Wow! That’s a lot of fan spacers!
I really appreciate all of the great info.
Now I just need to figure out which one I need. The factory service manual says I need a 1.72" spacer, but the factory parts catalog says I need a 1.06" spacer.
Chris
Chris
Measure the space between the pully and the radiator. IMO I think the closer you are the more air you will pull.
I think ideally there needs to be an inch between the leading edge of the fan and the radiator.
