moparmuscle68
Anyone know of source for seal kit for p/s pump? Car is 383 Fury VIP P/S pump can leaking Oring most likely but need kit if there is a source for it Last resort pull it apart and search for a o-ring??
Hello my fellow North Carolina C Body enthusiast. NAPA has the P/S seal kits for $20.00. Make sure to verify which pump you have as my recall is that Chrysler used 2 different suppliers whose pumps looked similar but wet a little different on the back side of the pump. Where in NC are you?Anyone know of source for seal kit for p/s pump? Car is 383 Fury VIP P/S pump can leaking Oring most likely but need kit if there is a source for it Last resort pull it apart and search for a o-ring??
ShelbyHello my fellow North Carolina C Body enthusiast. NAPA has the P/S seal kits for $20.00. Make sure to verify which pump you have as my recall is that Chrysler used 2 different suppliers whose pumps looked similar but wet a little different on the back side of the pump. Where in NC are you?
We’re pretty close to each other. I know that I have new replacement brake shoes that have asbestos.Shelby
You have some brake shoes 11x2 original? I need some...
