1967 Two-Spoke Wheel - Aftermarket?
BluegrassDan
Elizabethton, TN
Believe you'd have to change your horn ring if you were to use the earlier version. You might want to restore your original because you will have to paint it anyway. Can do it yourself or send it to someone if you're uncomfortable with that.
My 68 Fury has/had a 2-spoke wheel and I suspect it would be the same as yours. But verify, if so it widens your search criteria.
