mgm1986
I have the engine bay wiring mostly buttoned up and to finish testing everything I need to move under the dash so I pulled the cluster out yesterday.
First task. The fuel gauge. I know the sender had been replaced recently (and I know someone tried or did jack the car up by the gas tank ). Anyway, the first thing I did was test the volt limiter and it works, sometimes, if I touch it just right. But mostly it just puts out 12v and I certainly don't want to burn up the fuel gauge.
I read a post where some folks had used MeterMatch to get the gauge working correctly. If I read the instructions and website clearly, since I don't have a temp gauge, I should be able to use the MeterMatch as the 5v supply for the fuel gauge and not worry about replacing the Volt limiter mounted to the back of the cluster.
Before I buy the MeterMatch, can anyone confirm my understanding of what this cool little device can do? Thanks!
