SOLD 1969 dodge monaco part out
soliday78
Janesville wi
1969 dodge monaco 4 door part out im using some stuff for my own car.. car will not be around very long maybe 2 weeks
Thank you for posting. Do you have the fender tag, and interior shots?
I need the firewall section, from the heater box to the top of the cowl, and over to the brake booster. My drain hole under the wiper motor is rusted out.
Thank you for DH43F9R300217. Windsor built. Few options — but appreciate the reply.
Given this is a '69 Windsor plant car, I'd really like to see the broadcast sheet if you find one.
I bought this car from someone in beaver dam wi i believe the car was local to the fox lake area thats what the guy told me
I bought it for parts for my 69 2 door
That's right Beaver Dam I was gonna check the car out on a Sunday he messaged and said someone was buying the hole car.
I bought a car out of Michigan last year that needed alot of stuff.
Everything im using
1.The plastic thing that goes by wipers for leaves
2.front wheel wells they r mint
3.front core support it is mint.
4. Drivers side mirror
5. Drivers side door latch mine is broken
6.under hood wiring
7.under dash wiring
8. Bench seat track to fix mine when u press on gas the seat moves
9.grille
10.hood
11. Speedo cluster mine is missing some gauges
12. The plastic thing that controls floor vents by steering
13. The hvac controls mine are all broken tabs i believe my cables r good
14.the quarter extension pieces that are by tail lights mine are cracked with bondo
Car has a locked up 318
I plan on selling the 727 small block
