Furious Sam
I got mine 2years ago zero rust had taken apart bead blasted and painted b5 great car.is that a 69 dash?
Site keeps duplicating pics and adding them back when I edit them out.
Locating nodule for axle spring perch
U-bolts and shock mounts
Installed
8.75 mounted on leaf springs
8.75 installed
904 driveshaft longer than 727. Reinstalled 904, but still have 727 driveshaft
Trans slip yokes also different
NAPA 246 u-joint installed on 904 shaft
Yes it's from a 1969 Fury, although supposedly its correct for early 1970 model year Furys. The 69 dash pad was the exact color I wanted. I just didn't like the wood strip on the 1970 and $125 for that black dash was a lot less than $800+ at abcmoparts.com. I applied a Meguiar's vinyl cleaner/restorer for many days in a row. It came out excellent. The dash shell , instrument panel, and basically everything else in the dash is 1970.I got mine 2years ago zero rust had taken apart bead blasted and painted b5 great car.is that a 69 dash?
Wow. Looks like Shamu and your car are related!
Like your 69 Vert. Well Done!View attachment 356626
Wow. Looks like Shamu and your car are related!View attachment 356627View attachment 356628
PS Sorry about the B-25 pictures. That was at the Fagen Fighters WWII Museum in Granite Falls, MN. That is’Paper Doll’ on D-Day last year. They offered all of the WWII Veterans in attendance a ride in her. If you ever get up that way, go see the Museum. It is amazing!
Doing it right!Engine Block: Ben used a large cone with sand paper installed in a drill to chamfer the top of the 8 cylinder bores in order to aid installing the pistons and rings.
Later, not pictured
Die grinder: instead of surfacing disc, Ben used grinding disc to grind down protrusions of metal at seams and at openings. The point was to get rid of everything that was sharp or could chip off.
Electric Grinders: Used acorn shaped grinder on the end of the shaft to get rid of slag in areas that the die grinder couldn’t reach.
Some casting info for for reference
Stamp pad beside distributor, (from much later in process). E is 1969 model year date code.
8 digit VIN stamp at right side oil pan rail. 9 is 1969 model year. F is Newark Delaware assembly plant. Remaining 6 digits is VIN of car 440 originally from.
Main bearings, label, stock size because Ben Tillman measured crank and determined only polish needed.
Main caps
Bearings: rods, cams, and mains
Ben recommends against Plastigage. He mikes journal, bearing thickness, and inner diameter of main and cap (or rod and cap). He compares to Clevite spec sheet like below to determine bearing clearances and see whether in spec. B2 pre-1973.
Main Bearings, wall height (thickness): Clevite MS – 2324 P Made in USA. Book spec for max wall thickness/depth is .0959 inch. Ben miked them at .0955 inch.
Crankshaft Casting Number 2206160: Ben measured the main and rod journals to be sure that they remained at spec after crankshaft polishing. 2.7495-2.7505”. Rods still within 2.374-2.375”
Main Caps: I torqued them at 85 foot-pounds. Ben used the Clevite Bearings book and inside micrometer to verify journals size ID without bearings installed. Housing Bore: 2.9425-2.9430” spec. Measured within spec.
Deck Height: RS, install connecting rod and KB piston assembly with rod bolts 50 foot-pounds. Did cylinder number 4 first. turn Block until right bank is horizontal. Install piston and connecting rod assembly using Clevite boots on bolts. With piston rock, had a variation between .037 to .040 inch down below deck. Deck height is therefore .0385 inch. Cylinder number 3: turn Block until the left bank is horizontal. Reinstall same piston and connecting rod assembly using Clevite boots on bolts. Rocks from .038 to .043, deck height .0405 Inch. Given this deck height. 88cc combustion chamber, and .040 inch Felpro head gasket, we need to call Jim at Hughes engine and verify compression ratio. Hughes Engine supplied most of my rebuild parts.
Hughes Engine: I called Jim. I explained that the piston is .0385 inches down in the bore. I added that we are using a Fel-Pro gasket .040 inch compressed height and 88 mL 906 cylinder heads with stock 3.75 inch stroke and the cylinder bores bored out 30 over to 4.350 inch. Jim responded that if we took .010” off the top of the block and .010” off the heads, which would restore the heads to stock position (original steel shim head gaskets were about .020" compressed height), we would have 9.25:1 compression ratio which would be okay with 93 octane gas. He does not recommend going any higher with iron heads.
Crank after polish, install with main caps 1/3/5
Rotate block 180° and check height with this dial indicator tool, light green color. (Picture of tool at top of cylinder didn't come out clear, so no pic of tool in action). Imagine the tool straddling the cylinder and the piston head hitting the needle for dial indicator. Deck height is minimum reading.
I made notes every dayWow! Impressive. I've never had the opportunity to see any of this. How do you remember all these numbers?
