GJS
Not mine but DAMN sure wish it were:
1973 Dodge B200 Sportsman 440
1973 Dodge B200 Sportsman 440 - $7500 (Woodbridge)
1973 Dodge B200
fuel: gas
odometer: 45000
title status: clean
transmission: automatic
3/4 Ton Sportsman Van
45,000 Miles
Original motor was 360. It was replaced with a 440 from a 1968 Charger. Tags are on the motor. (Approx 5,000 miles on rebuild)
Motor was Performance built by Bob Chipper. (Member of "Drag Racing Hall of Fame") It came out of one of his Chargers.
New everything. Bearings, Rods, Valves, 60 over Pistons, Low RPM/High Torque Cam, Headman Headers, etc.
Since purchased, here is a partial list of work performed,
- Front brakes, Calipers, Hardware, Hoses, Seals, Master Cylinder, Rotors.
- Rear adjustment Kits, Seals
- Compressor,
- Electronic Choke Kit
- H.D. Wire Set, Wire Separator & Wire Loom Kit
- Fuel Pump
- Transmission Filter & Pan Gasket
- Fuel Line
- Racing Starter
- Voltage Regulatior
- Belts
- Alternator
- Complete Service
Interior Has ice box, 2 Burner Propane Stove, Sink w/ Electronic pump, Clean Water Tank, Drawers, Cloths Closet, Couch/Bed
Extras - Air Horn,s, Isolator for 2nd Battery, CB, 2 Gas Tanks, Sun Roof, New Tires, Extra Fuse Panels under the hood, Frame Hitch, Etc.
Van is not perfect, but it doesn't need much
I have been offered $4,500 for the motor alone, I WILL NOT Separate.
You can buy the van and do what you want with it.
$7,500 the way it sits.
Please call for more information!
1973 Dodge B200
fuel: gas
odometer: 45000
title status: clean
45,000 Miles
- Compressor,
- Fuel Pump
- Fuel Line
- Racing Starter
- Belts
- Alternator
- Complete Service
