65 300L 413 Electonic conversion
straightjob
Northern New Jersey
Good morning i want to convert my 413 dual point to electric , what is the best i can buy Dist /componets etc , i dint want to be stuck with import garbage, i m tired of points! Car flutters on acceleration also does anyone know the dwell and point gap??? Thanks
Duel point dwell each point set is 28-33 both believe it is 42. Petronix conversion is the way to go with that one. Nothing wrong with points if they are good quality.
If they are new parts store good luck look for a older set if you can especially the condenser.
They should be good for 10K miles. Check if the cam plate is not bent (upper shaft) that would throw the dwelll off. Petronix is easy to installl.
When I had a 440 6bbl cast iron dual point distributor (with the Mopar Perf height adapter) in my '67 Newport 383, it ran generally good, but I never could get the points adjusted to get the extended dwell the dual points should have. One night, I pulled it out and set it up in a vice and measured the point gap with a dial indicator. THAT's when I discovered that the lobes on the distributor cam were worn enough that if I set the gap at spec, the dwell would be off, and vice versa. THAT's also when I bought a Mopar Perf conversion kit to replace it (back when their kits were better than they now are). End of story.
Bad thing was that few of the lobes' peaks allowed for a "good" point gap to specs, which I'd never considered to be an issue. Back then, we just put new points in, lubed the lobes with the cam grease that came with then (in a small plastic vial), set the gap (on whichever was the closest lobe peak), and all was well. Sometime in the 1980s, that little vial of lube was not with the point sets I could find locally, which also tended to coincide of others with points not getting 10K miles out of a set, by observation.
The OTHER issue with points is that they exert a spring pressure on the upper dist shaft bushing, unlike the factory OEM electronic distributors where the shaft just spins. That wear might cause an issue if the bushing is not renewed.
There can be a bit of additional wiring that will need to be run, plus one of @FURYGTs electronic voltage regulators is needed too.
Are the spark plugs and plug wires recent, too?
When it's all done, it should be great to drive that 300L again, I suspect.
I put a Mopar Performance Electronic conversion kit on my '65 years ago, absolutely trouble free (several other cars too). The new MP ones have a lesser track record for the distributor, a lot of stuff crammed into the OEM look housing.
So, get the ECM, the wire harness, etc. from Mopar Performance (use Mancini Racing in Detroit) and get a used or reman distributor for a 1973 version of the engine you have. In general the original MP kit had a very race oriented advance, so for a daily driver it was useful to swap the stock advance weights and springs from your original distributor anyway.
Remember to swap to an electronic alternator regulator if you have the old point style.
Mark
