barsteel
Hello!
When I took my '65 Fury home, I knew that the motor was tired. It smokes, ticks, and generally runs like ****. The (broken) odometer shows 38k miles, so my guess is that the motor probably has close to 150K on it. The car is a Fury III 2 dr hard top with a factory 4spd and a 383 that was a 2bbl but is now a 4bbl. I believe that the rear end is in the 3.2:1 range (factory).
I will not be building the engine for the strip - it will likely see 100% street use. I believe that "there ain't no replacement for displacement", so the plan so far is to use a stroker kit from 440 source to get the cubes into the mid-400s, (450 or so). I will likely never spin the motor much over 5k, and I'm planning on having a well recommended local machine shop build the engine. I have a budget of up to $7,000.
Since I'm spending the money, I want a fast car. Given that the Fury is a fairly heavy car, and that the rear end gears are somewhat high, it seems that building a motor for maximum torque would give me what I want, hence the stroker kit (longer stroke = torque).
Here's what I'd like to know:
1) I have 2406516-8 heads, which have 2.08 intakes and 1.60 exhaust valves. They were used on 64 - 67 361/383/413/426 engines. Can these heads give me the torque needed to get the Fury rolling, or should I spring for aftermarket heads?
2) The engine has an newer Edelbrock 1411 (750cfm electric choke "performance with economy" rating from Edelbrock). The machine shop guy says that a Holley "will get me at least 20 more hp" than an Eddy. I did some interweb reading, and not a lot of people share his opinion. Some people like Hollys, some like Eddys, and they both seem to perform well on all the test reviews I read. Am I really better off with a Holley?
As an aside, Edelbrock's website says that the 1411 "should not be run on an RPM manifold or a Torker II.
3) The engine also has an Edelbrock Torker intake. I've read that I'd really be better off with a dual plane intake for the way I want to drive the car for. Thoughts?
4) I've heard that the stock Chrysler exhaust manifolds flow very well. True? Not true?
5) Of course, there's the camshaft question, which I haven't even started looking into, although I will very likely be staying with a flat tappet hydraulic cam. Thoughts on Specs? 440 Source seems to love Comp Cam Xtreme Energy Hi-Lift .545 and Comp Cam Xtreme Energy Hi-Lift .564"
I hope I'm not kicking a hornet's nest here, but I'm looking for opinions on how to approach this build.
Thanks...
Chris
Thanks...
Chris
