65 Chrysler Tilt Column Turn Signal Switch Cable Assembly
michiganhotrod1
Detroit, Mi.
Hi all;
I recall reading that someone found a source for the cable that operated the turn signal switch. This is a Saginaw sourced tilt column, and a similar setup was used on both tilt and non tilt gm cars from about 1960 to 1965.
The cable is 24&7/8 inches.
All of the google searches found cables that are a couple inches shorter.
Anyone know who might make these??
Thanks.
Mark
Nope, wasn't me. However, I would suggest seeing if the GM crowd has a source. Could easily be custom made, as it's a simple bowden cable.
