barsteel
Hello!
As I wrap up the 440 install on my '65 Fury, I wanted to fix some of the other small issues while I had the car apart. One of those things is/are the dash lights. None of the idiot light work, and I'd like to test the speedo before I hook up my new speedo cable, so I have to remove the instrument panel.
Here's the issue - I removed all of the external screws from the instrument panel and dropped the steering column, and the panel will not come out, so there must be some screws that I'm missing.
Where are they? Is the instrument panel screwed/fastened in from the backside? I crawled under the dash, and it seems like there might be two screws at the top of the instrument panel from the backside. I'd like to confirm before I crawl under the dash because, honestly, it's a painful experience.
Thanks...
Chris
Thanks...
Chris
