1. 65&66Fury
    65&66Fury Member
    95
    2
    Jan 28, 2011
    Don't really know my Plymouth transmissions yet. Since I have the 273ci V8 what tranny might I have?
  2. myforty
    myforty New Member
    8
    0
    Feb 12, 2011
    Iowa
    Did u say u had a 66? maybe 3 on tha tree?
  3. rapidtransitrick
    rapidtransitrick Active Member
    318
    1
    Nov 7, 2010
    richmond illinois
    well there you go is the existing trans a manual or automatic?
  4. rapidtransitrick
    318
    1
    Nov 7, 2010
    richmond illinois
    the 727 oilpan will look like the top gasket. the 904 is the bottom
  5. 65&66Fury
    65&66Fury Member
    95
    2
    Jan 28, 2011
    OH DAMN I sound like such a newbie! Duh, I have an auto tranny.
  6. CBODY67
    CBODY67 Senior Member
    3,943
    904
    Mar 27, 2011
    Trans is most probably the A-904. It can be rebuilt and upgraded to work fine behind a normal 360 V-8. PLUS it takes less horsepower to run than the A727 does.
    One MAIN reason to stay with the A-body engine family is the wiring harness and other things between A-blocks and B/RB-blocks in C-body cars is that so many things are on the opposite sides of the car! Exhaust pipe is one (A-blk = lh side, B-blk = rh side . . . for single exhaust systems. Many other wiring harness "things" too. PLUS, the total weights will be similar so the torsion bars will not need to be adjusted too much.
    The 360 has more lower-rpm torque and that will make the car act much better, even with the normal 2.94 rear axle most of them had. Just a good "wrecking yard" engine will be fine, but you'll probably want to see what's "inside it", for good measure, before you install it. Most of the 360s were 2bbls, most having the Holley 2210/2245 versions, except for the 1980 model. The 4bbls were spreadbore Thermoquads, but you don't need that much for a stock engine.
  7. 65&66Fury
    65&66Fury Member
    95
    2
    Jan 28, 2011
    Thanks for the info! Will put it to good use.
  8. commando1
    commando1 Mr. Normal FCBO Gold Member
    32,564
    17774
    Mar 10, 2011
    FUHOA Reservation, Sebring, Florida
    I had to read this three times to make sure I didn't miss something.
    66 Furies didn't come with 273's.
    Base V8 was a 318 wide block.
  9. rapidtransitrick
    318
    1
    Nov 7, 2010
    richmond illinois
    well stanly..... there you have it.
  10. 65&66Fury
    65&66Fury Member
    95
    2
    Jan 28, 2011
    You guys are completely correct! After much research and help from some good friends on FCBO I found that she has a 318 Poly.
    I have decided to keep the old 318 and just tune her up.
