Furydude
I found my 68 a few years ago and right after life interviened and I shelved it. It is a nice car but a bit of a leaker. Dif, trans, and engine all have some type of leak. Plus the brakes just plain ol suck. I am off the COVID couch and working on the car.
First up is the rear. I could not tell if its the pinion seal or the carrier/case. I am hoping the pinion seal. It has a 742 case and it seems I can drop the drive shaft, remove the yoke, pinion seal, and pop in a new one. Then snug it all back to factor torqe specs. While I am there I will replace the u joint and disassemble the brakes and put in new brake stuff.
Any suggestions? Or hints.
The brake lines look sketchy. Orginal. I think i'll replace them all the way up to the front. Get the rear brakes all spanky new. Any suggestions on where I can get pre bent lines? Or maybe its easier to pull the old and bend new ones using the old ones as a template. I have never done this but think i can get a bender and flare tool and figure it out.
Appreciate any feedback. Thx, Tom
