I have a 69 300 vert w/ a 440 and 727. After warming up the engine would really struggle to idle at stops while in drive. It would also stutter and surge when i really put my foot down. I fixed a vacuum leak and it helped. I then checked timing and I was at 19 degrees advanced for TDC. My manual said specs for timing were 7.5* before TDC so I retarded the timing and the rough idle and sluggish acceleration are gone.
Anybody have any thoughts on the timing i mentioned above? would being too advanced cause those symptoms?
What is the curb idle recommendation for a 69 440? i am at 650 rpm currently.
Also I was gonna use a vaccuum gauge and set my carb mixture what are you all typically getting at the manifold? 20-21?
Thanks again for any help this site is great.
