furyus 67
Looking for some opinions on where to mount the 6al. This to me seems like a good spot, but I'm not sure if the hood spring bars will be banging on it. Where have some of those of you have them or have had the put them?
I thought about moving the horns and putting there.mmmm.I never mounted one on a C-body myself, but I would look on the radiator support (facing the engine) rather than the firewall. It will be a little cooler there.
yes it is commando!!! But it's my $250 humongous rev limiter!;) 1- eliminates those wonderfully reliable ballast resistors! 2-the build in my mind is part hotrod,part cruiser and part low rider. But it's all mine!I can't hold back any longer.
The thread outlasted my ability to keep my mouth shut.
It's a $250.00 humongous rev limiter. ..![]()
ld_school:
Reliable,easy to use and many applications. I know a lot of hotrod,custom and muscle car guys and they came highly recommended. A set it and forget it kinda thing. I doubt this will be the last car its installed on.Just curious, but why a 6AL. There are many other options in most cases.
I've had MSD ignitions in 3 vehicles and would recommend them to anyone. The best application was my A12 Roadrunner. That car was jetted a little "fat" and had a pretty lopy cam in it and would occasionally load the plugs. The stock ignition worked OK, but everything had to be right. If the plugs were the least bit fouled, forget it... there was no starting that car. A switch to the MSD and a .055 plug gap and no more problems. If there was gas in the cylinders, it didn't matter what the plugs looked like... It started and ran....
That ignition is 25 plus years old and still on the car with the new owner.
I also ran the MSD race unit (7?) for a few years on my race car after talking to some of the guys at Chrysler. It ran flawlessly and I never again had to warm the car up and switch plugs like I used to do with the Mopar Perf unit.
