Sir Patrick
Sir Patrick Your linkage is hooked up wrong, the return spring bracket is twisted around, return spring is too short, and you’re missing the spring on the throttle pressure linkage.
hwyycrzr Your green return spring is in the wrong place, it too low to pull. It should be connected up where the throttle cable is. That’s probably why there is another spring added on, so it will return the throttle.
Is this correct so far?
Not sure where to find the 2 proper springs for this application.
