The belts on my 383 for my power steering and alternator are loosening after about 100 miles. The first time I thought I might not have tighten them down with enough torque, because none of the bolts were loose. I was surprised the second time it happen and on both belts again.
The engine runs very smoothly, so I don't see that vibration is the issue. None of the bolts felt loose in fact I need to loosen everything up to move it to the proper tension. What is the proper torque, is this at all common?
