commando1
I feel this was the better choice. Regardless, you will never regret it.
You thought you had a "space issue". Right.......It was honestly a space issue, then I realized the scissor lift would be in the way too.
Yet my wife needs every square inch of the entire two-car side part of the garage to park her Mazda...You have me bea Stan. That is what I can maximizing every inch.
Cost of doing business... at least the classics are beyond harm there. Mine was upset initially... she had the delusion that she might someday get an indoor spot. One Imperial or Two Imperials, I explained that was never going to happen. She still needs to buff the Toyota paint off my Suburban from the last time she used their Sequoia. Fortunately all four corners of that thing were scraped up so they didn't notice.Yet my wife needs every square inch of the entire two-car side of the garage to park her Mazda...![]()
And the next time I see one for sale reasonable... which isnt often, I will have to park a Twin on 2x10 runners so I can store it. Maybe someday I will get that backyard garage... but the little scissor lifts arent quite as nice as having the 2 post... I just dont have the width or the height in my garage to use anything else.The vo-tech where my son took auto shop has three of these lifts, plus four two-post lifts, a four-post alignment rack/lift, and another four-post lift. Like anything else, you just need to take the proper precautions under these. The short racks are great for brake work, axle and suspension work, plus I have seen one used for putting an engine and trans with K-frame under a '68 Coronet. Pretty cool pieces of equipment, especially if you do not have a lot of room.
Funny... In my "grunt" days I was assigned the lift nobody wanted. A very nice Gilbarco twin post in ground lift... It had a car fall by some former tech, who was fired long before I was around. Car wound up in between the posts on its doors and they had to drag it out with the wrecker. One of the cylinders was tweaked, when you were going up you could watch the pads going out, out, out and then back in. It taught me to set the pads deep under everything... if it shakes off, the lift arm will still be there to catch it.Back in my service manager days, I can't tell you how many times I made a mechanic re rack a car. Amazingly these guys would be working on the car with it sitting on three of the four posts. I never had a car drop, unlike a few others.
I ordered the lift I've been looking at forever 9 ton 2 post, low clearance. I got all the grunt work done today set the two post ran the hydraulic lines and cables. Hope to finish the electric and the rest of the assembly tomorrow.
Nice looking lift. I'm curious, did you know the thickness of your concrete slab beforehand, or did you drill a test hole to determine thickness before ordering the lift?.
No. 6" is min. for under the posts.Thanks. Yeah, I'd read that 4" is the minimum necessary for a 2-post. I haven't had the courage to drill a test hole yet....
It looks like it got caught in the yellow tape on the way down.I have tried, and tried, and tried, to figure this one out. I can't.
