Mick
My '66 Imp was blowing oil (I thought) out of my breather cap and onto my exhaust manifold, creating periodic smoke episodes. PCV? Clogged breather cap? Stuck rings? New pcv valve and some seafoam. No change. What I had noticed was the oil collected on the forward sparkplug wire separator, the brake fluid reservoir appeared damp, and the high pressure power steering line appeared slightly shiny close to the pump end, as did the black insulation padding on the steering line. Finally, after pulling that insulation back, I realized that it was soaked! Of course, I immediately checked the PS fluid. Damn near empty.
Long story short, put a new line on, problem solved- almost. Tried the bleeding method of turning wheel to each stop like thirty times. No bueno. Noise still there when wheel brought to stop.
Suggestions?
Suggestions?
