Brake caliper bleeder screw hole is too large? Why?
Lordofthepings777
North Carolina
Recently I pulled my seized brake calipers off my 73 Newport. I found quickly you can’t buy replacements, so I was stuck with a few options:
#1- buy used and hope they aren’t seized
#2- send mine off to get fixed for about $160 each plus shipping
#3- attempt to fix mine by soaking in vinegar to loosen up the rust and replace gaskets+pistons for less than $30.
I ended up going with option 3, and soaked them for about a week to a week and a half. One of them, however, after being taken out has a slight issue. The bleeder valve hole… seems to be too big to screw even a brand new bleeder screw into! Why might this be? And is there any way to fix this? I mean- I thought maybe there was some sort of adapter on it and I just lost it, but it’s only barely too big for my bleeder screw to fit. Maybe like 1/16 of an inch or something bigger, so I don’t think there was ever an adapter.
I left some photos for reference, and the other one was not like this. Any advice here would be great, OR alternatively if there is no saving this brake caliper I would be open to buying any Chrysler 69-73 drivers side brake caliper from part cars. Let me know. Thank you!
Did you remove the bleeder screw from this hole? The third picture some semblance of threads. The first picture seems to illustrate a hole through to the table.
Sometimes, a rebuilder, they would use an oversized bleeder screw if the hole was stripped out. While it fixed the immediate problem it left a "bonus" for the next poor sob who needed to replace the bleeder screw. If you have the bleeder screw that came out, you might be able to use a die to get the thread count and size to try and source a screw that will fit the hole.
