C-bodies in France.
My condolences to the family Xavier..
Can you give us more details and pictures of the car and it current condition please?
oh sorry !! Never saw you answer !
CAr is running, body in bad shape, a lot of work on it. I bought another one with considerably less work on it, either to cur or to swap.
Good points are : interior is very nice, new carpet, and engine was redone before bying.
So, i still have the hurst so I am working on it a bit. And it is not very easy with the quarantine here. I can't buy anything and have only simple tools, living in an appartement, not garden etc..
So I rebuild the headlight motor using a milk bottle to make the gaskets and an ols cd ot make the plate... :)
I found this tiny piece and do not know where it goes.. can someone help me ?
Hi Xavier, greetings from Czech Republic. Do you still have the wagon without the title? If nothing has changed in our legislation lately, we could get the title for historical vehicle just with the purchase contract. Maybe you might be able to get your plates when imported back to France based on the historical title? Just idea to consider. How about other countries maybe closer to you, like Belgium or Germany, did you check the procedure and then re import?
My country have age limit for vehicles made outside EU / without EU certification (popular are muscle cars, pickups or big SUV) and needs to be 8 years old or younger, in order to be eligible for registration and obtaining title. No EU certification require to pass few technical tests which could reach costs up to 2,000 USD. Anything older, can not be registered unless have a title from EU. To pass this obstacle, its not uncommon to get the German registration first, where is no this age restriction. Then you can proceed as standard import being under age of 8 years. Long story short, just the missing title should not stop you driving your car and hopefully you might find some way around the legislation.
For the historical title, the car must be in very good shape, no rust and mechanically sound, nice interior. Lately is accepted "california sun" patina until certain level and mainly minimum age 30 years. In France, you do not have anything like historical vehicle title?
The condition for historical vehicles in my country are very good, cheap insurance (usually 1/12th of the standard rate - 20 USD per year in my case), renewal check for condition every 2 years (40 USD) and must be member of some historical club (100 USD). Actually I passed today the TUV inspection for the brake check and goes for renewal check on Friday - this time because of covid, it will be kind of drive inn to keep the social distance.
Hi sorry i did not answered back.
thanks for your offer, maybe it is to consider :)
What do you need ? can it be done via mail ? because the car can't run right now.
some new !
So it has been a long time. I do not have many cars now. i had to change plans because i do not have anywhere to put many cars now.
So the citroen is gone.
The hurst is gone ( too much work for me with no room )
I have a 68 corvette and i still have the 70 monaco.
the monaco will move in belgium to a friend.
so the week end i did some work on it to be road ready.
i bought a PST kit yeeaars ago for it :
Perfect kit, everything match.
to be fair, if you have the right tools it is kit easy and fun to do. It went perfectly well.
With the proper tools we removed the front end in 2/3 hours.
The only bushing we didn't do are the lower arm ones because of lack of time and incertitude for the removal of the torsion bars. but they still are to be done.
quite everything is here :
went to a friend for removal : it can be done with hammer but for the ball joint it is better with a press. We removed the upper bushing and put them back just with a hammer.
old ones :
took back on the car, it is quite easy too. And then a brief setting to be good.
still had enought time to remove the interior for rust checking, under the windshield too.
replaced the steering box that was defective and go.
replaced spark plugs ans wires, oil change, checked the carb that was leaking and ok.
Hi, apologize for the late response. It's a way more complicated process requiring a physical presence of the car passing the technical inspection and the car must be in very good condition in order to acquire historical plates/documents. You must be also a member of the historical club. It might be the vital option only if it cannot be done elsewhere since it does not require a title but a purchase contract with VIN indicated, is enough. Nothing is so easy as it seems, we are not living in the USA where it could be done via mail, sorry :-)
i still have the 70 monaco. the monaco will move in belgium to a friend.
Sorry to hear that the Monaco will be gone, but at least it is going to a friend of yours. If you have more photos to post, including ideally the fender tag (PhotoBucket lost in in the "for sale" threads from Oct. 2015 and Jan. 2016), that'd be great!
Hi, monaco is gone and not gone at the same time. It is always a bit complicated with me.
Car is at a friend's in belgium and very very well cared. It is a resurrection.
Lately we are searching for instrument cluster ( or at least fuel and temp gauge that are broken ).
Electricity ill be the next step next year.
My friend wants to buy it but for kiw he has the car to enjoy and use as of it was her.
He kind of customise it a little but do not worry nothing easily removable, i am very clear with that : a valuable car is a matching, original car. And if modified, keep original parts and nothing permanent.
The 300 hurst is gone in middle of france, too much work for me, i do not have the space for big body work.
Have a nice '68 l79 corvette and still my caddillac hearse.
My biggest issue is the polara wagon. I will make a thread for it.
the Hurst : (...) no A12 code on the tag. on the build sheet I have the special order, but no A12 specially mentioned. There is a A12 but I do not belive that this is the same thing.
All other thing matches.
In 2004 the 300 club edited a registry on the last known 300 hurst :
And mine is in there. :)
the build sheet too :
@Xavi3r -- do you have pictures of the fender tag and the door tag for your Hurst?
I do not have the hurst anymore but i can have that.
Having a photo of the Fender Tag and the Door Sticker (showing the date) would be greatly appreciated. If getting a photo is not possible, perhaps the current owner can simply tell you the VIN, and the date on the door sticker. From your Broadcast Sheet photo from Post #14, back in May 25 2014 I can see that the Vehicle Order Number is J99518, which is also on the Fender Tag. Unfortunately, the second-to-last number on the VIN is difficult to read. I believe the last six numbers (the important ones!) are 196875, but the Fender Tag will confirm that if it is a 7. As you can see from the red mark on the Registry, 196875 and J99518 would fit right in below 196874. [The VINs and VONs often don't follow strict numerical order, but yours is very close.]
And here is your former Build Sheet, showing J99518 and 1968?5.
Thank you in advance for your efforts to get this information for the Hurst Registry, especially that Door Sticker date. :thumbsup:
The Hurst Registry
@ayilar
The Hurst Registry
@ayilar
Hi you are lucky i already made contact when i got the hurst and made pictures.
I contacted gloria moon, do you know her ? She has a registry of 300 and hurst.
Another nice man, bob meritt adviced me about the hurst back in the days.
I join you the pictures.
At he end, i kind of miss my hurst.
View attachment 706371View attachment 706372
FANTASTIC! I will be adding your former car to the Registry and will be posting a new document in a week or so. I'm waiting on some other info to come in on some other cars before I do that.
I've met Al and Gloria Moon, and many members here know them well. Nice people. I believe her Registry is a list from the Chrysler 300 Club International consisting of about 280 VINs, the owner's name and the membership number......nothing else. Al Moon and Gloria are officers of that Club. I also have that list, which is very similar to the printed list you posted back in 2014, which I also have a copy of.
Thanks again for getting these photos.
Oh, to answer your question from 2014, the A12 was added to the Fender Tag "probably" when the VINs reached 200000. I have a lot of photos of Fender Tags, and none of the 19XXXX tags and all of the 2XXXXX tags have the A12 like the one shown below. But your Broadcast Sheet did have the A12 designation in the "A" block.
