I’ve got lots of lighters but none that style, most are like these.
I do have shorter ones from the mid ‘60s Imperials too.Matt, I'm not sure that pic shows the correct lighter in the rear ashtray. It looks like the standard front unit which may well be too tall to fit under the sliding cover on the rear try. Mine has a much different, (shorter), knob on the rear lighter.
Those I have.Okay, a little fact check. The standard front lighter knob will not fit under the cover when closed. It's possible they made a shorter version of that one for the rear but if so, I don't recall ever seeing one.
The two I'm used to seeing, side by side.
And a top view to show the design on what I *think* is an original rear cigar lighter.
I turned over a new leaf this year Rip and that is to buy parts that cross my plate.Matt: I didn't know you were such a pack rat. Thank you!
Those I have.
Ok, well you see what I have so if you can’t find one you think is original I have some that’ll work pictured above.Thank you for your time and patience
Good luck - I've never seen a short one with the ribbed sides as on the front, longer units. The one I showed was the one in the console when I yanked it many moons ago.I would like to find an original one ribbed on the side.
