DDR2467
Hello all, just got my car back from having some things done, one was the distributor cap was replaced. I picked it up after work so when I drove it away I couldn’t ask the mechanic abut the issues that were present when I started up the car. As I drove it down the road there was conciserable a mount of sputtering, no power, almost felt like it was going to stall. I believed it could be a timing issue or a vacuum issue but upon further inspection I noticed this piece which is bolted to the block next to the coil, between the coil and the distributor. It’s the size of a “C” battery and only has a 3” wire with a ring terminal at the end of it. Before I call the mechanic back and have to limp it back to the shop, can anyone let me know what this is and if it could possibly be the reason for the “misfiring” issue I am having? Thanks in advance!!!
