I like a reverse pattern manual valve body with a column shift. I modified a 67 B body to work that way. I had to weld up the gate and then grind it.
The operation is nice. You put it in 1 at the line, take off and just push lever straight down for second. There is a stop there. You cannot miss second. Then for third you pull shift handle towards you and down. Again you can't miss the gear. These movements are gentle and easy, they are not hard on the column. You are not speed shifting a tractor. You don't need to be rough on the column. I'm sure many remember the ford pickups with broken column shift collars?
1967s have a brass bushing inside of the rubber grommets were the linkage goes through, with a thin flat washer on each side. Also held together with those spiral spring clips, not cotter pins or bent nails. Many people don't know this and they leave the factory hardware out and it makes the linkage sloppy.
