Cop Wheels and Dog Dish caps
Mopar Wagons
  1. moparlouie
    moparlouie Member
    82
    11
    Jul 30, 2015
    ct.
    I have a set of caps!
  2. Snotty
    Snotty Senior Member FCBO Gold Member
    2,854
    929
    Aug 18, 2015
    Chico, California
    IT's all opinion, but I say no to poverty caps. Then again, I say that to any and all cars with them. There's a reason people threw them away when these cars were new.
  3. furyusvip
    furyusvip Member
    60
    47
    Feb 6, 2011
    Outside of Chicago, South Holland, IL
    Well I still like the poverty cap and steelie look...
    • Like Like x 2
    • Agree Agree x 1
  4. Turboomni
    Turboomni Senior Member FCBO Gold Member
    4,067
    1756
    Dec 14, 2015
    MA
    I love the look of steel wheels and dog dishes. Some cars I personally feel look better than others with them.
    I run them and like them alot.
    • Like Like x 4
    • Agree Agree x 2
  5. furyusvip
    furyusvip Member
    60
    47
    Feb 6, 2011
    man...that's a good looking 69! What have you done to it so far?
  6. Turboomni
    4,067
    1756
    Dec 14, 2015
    MA
    Thanks! She has a new front end as the old one was most likely original,,shocks, new dizzy [points!] Lots of little stuff ,tires and wheels and now since the old 440 is a bit tired I am getting together a build for a stroker 440 to 512,with aluminum heads etc. But keep HP exhaust manifolds. No Cuda wanna be here,,no big lopey idle but just massive torque with highway gears to move this old big boned gal with real authority and idle with a slight lope on pump gas. I am finding this a bit of a challenge cause most want big huge power but it ain't the kind of ride that my wife will ride in and frankly I don't want to deal with. Power brakes, decent to nice idle and massive torque when needed.
    • Like Like x 2
  7. furyusvip
    furyusvip Member
    60
    47
    Feb 6, 2011
    um, that should be EXTREMELY easy with a 512. Just go easy on the compression ratio and install a nice torque producing Hydraulic roller and you'll be flashing your highbeams at them slow pokes in the fast lane!
    • Agree Agree x 1
  8. Turboomni
    4,067
    1756
    Dec 14, 2015
    MA
    Sounds like you speak from experience. Fill me in.
  9. BLIMP
    BLIMP Senior Member
    1,017
    1099
    Sep 13, 2017
    Illinois
    A couple pics from when I visited @Xenon weeks ago Screenshot_20190610-205113.png Screenshot_20190610-205207.png
    • Like Like x 2
  10. DonC
    DonC New Member
    44
    35
    Jul 7, 2019
    Oakville
    That is awesome! Looks just right!
    • Thanks! Thanks! x 1
  11. Turboomni
    4,067
    1756
    Dec 14, 2015
    MA
    Actually that is what I am doing. Conservative compression ratio of 9.8 to 1 with a custom grind hydraulic roller cam and a 3.23 rear.
  12. furyusvip
    furyusvip Member
    60
    47
    Feb 6, 2011
    In 1998, I built a stoke stroke 440 with Indy SR heads, solid roller cam in the .650 range, Indy dual plane intake, 850 Demon carb and it made 570hp/tq under 6,200 rpm. I backed it up with a 3200 stall, full manual 727 with a brake, 4.56 gears and a 29-31 inch tall tire. I eventually tamed the dana with a 3.73 gear and it made it even better in the left lane.
    Your best money will be spent on the heads, even with a 'mild' hydraulic roller (under .600 lift) you should be able to produce a fantastically flat torque curve that rarely drops below 500 tq. Idle should be noticeable but somewhere between 700-900 rpm. You'll need some kind of stall, but it won't hurt street manners.
    • Like Like x 1
  13. Old Mike
    Old Mike Active Member
    205
    253
    Nov 24, 2018
    Overbythere
    I’ve always liked the dog dish look. They give the car that purposeful look. Otherwise I prefer the road wheels over the mag 500s.
    • Like Like x 1
  14. furyusvip
    furyusvip Member
    60
    47
    Feb 6, 2011
    I used to like the Cbody Road Wheels, but my cars were never 'pretty' enough for those or the popular Magnum 500 rims. Not to mention, Poverty caps are cheap (or used to be anyway) and a very quick and inexpensive way to change the look of your car. I really like the 68-72 Plymouth cap, the salt shaker police version and the solid 'Plymouth Motor Division' ones as well. My 84 Dodge van has the 'red line' cap covering the lugs.
    • Like Like x 2
  15. Dsertdog
    Dsertdog Active Member
    209
    199
    Feb 19, 2019
    Oklahoma
    I've never understood the fascination with poverty caps and steel wheels.
    Is it guilt because you threw them away when you were young and stuck those Cragars on?
    Or the karma is doubled because you put your snow tires on them? Oh the sadness...:rofl:
    Either way, I'll never understand it...but hey it's your car.
  16. 1966 t and c
    1966 t and c Member
    55
    75
    Aug 9, 2017
    north carolina
    You've got a great looking wagon there, gonna look good regardless in my opinion. I have the magnum 500s on my wagon and until recently had thin white walls on it. There was just something about that look that didnt seem right to "me". I considered several changes and finally decided it was the white walls that didnt suit "me". I changed the tires to T/As and I'm very pleased with the white letter look with the magnums. The white walls are certainly appropriate for a wagon but to me they just didnt look right with the magnums. I would suggest you look at the photos we've all posted, ignor everyones opinion, and go with the look that suites you the most! Its your ride! And a very nice one! sw wheels 2.JPG sw wheels.JPG
    • Like Like x 3
  17. SportFury70
    SportFury70 Well-Known Member
    520
    319
    Mar 8, 2019
    Berlin, CT
    @crazyboutwagons. I would honestly keep the Magnums on the car. I think they look great, and they set off the car and give it a special and certain look. (That I cannot describe). Just my opinion. I am not "knocking" the dog dishes, they would look good too. Here is an example of @billyfury's 70 Sport Suburban I took at Carlisle this year. If you need cop car wheels, I believe @FURYGT has some IMG_4909.jpg
  18. FURYGT
    FURYGT Senior Member
    2,214
    910
    Mar 11, 2017
    Middletown, CT
    I do not have any cop car wheels for sale.
  19. crazyboutwagons
    crazyboutwagons Active Member FCBO Gold Member
    339
    137
    Dec 7, 2011
    Pittsburgh,Pa
    I bought a set of c-body road wheels last year .just haven't gotten around to cleaning them up.need 2 caps.that will change shortly.retiring at end of July so will have the time.1966 T&C love the look of your wagon .
  20. SportFury70
    520
    319
    Mar 8, 2019
    Berlin, CT
    Oops. Sorry Bill, I thought you had some at Carlisle for sale?
