1. 67Monaco
    67Monaco Old Man with a Hat
    5,178
    2345
    Nov 20, 2010
    Punta Gorda FL
    Specifically removal there of.
    I have all six bolts out, as well as the damper bolt itself out. The pulleys act like they're still bolted down. Gentle pry yields nothing.
    Anything I'm missing?
    Most damper pulleys I've ever taken off pretty much just fell off.
  2. Davea Lux
    Davea Lux Senior Member FCBO Gold Member
    3,257
    797
    Mar 27, 2017
    Cornelius Or
    Spray the inside of the damper pulleys where they contact the hub with some spray lube, there is probably some rust on the hub.
    DAVE
    • Thanks! Thanks! x 1
  3. 67Monaco
    5,178
    2345
    Nov 20, 2010
    Punta Gorda FL
    got it, bigger persuasion bar was needed. Factory paint glued it together.
    • Like Like x 2
    • Agree Agree x 2
  4. LocuMob
    LocuMob Fluid Technician with a hat FCBO Gold Member
    8,278
    4266
    Oct 31, 2013
    Blue Earth Mn
    I had to beat the crap out of a pulley I took off this year, I thought they welded the damn thing on. Biggest pry bar I had and anger got it off.
    • Like Like x 2
  5. 67Monaco
    5,178
    2345
    Nov 20, 2010
    Punta Gorda FL
    I used a .5" solid round bar 4ft long between the sway bar and the edge of the pulley. went side to side and popped of in two tries.
  6. 65sporty
    65sporty Old Man with a Hat
    5,912
    1297
    Aug 24, 2013
    Marlette,Mi
    I was going to suggest a bigger hammer:D
  7. 63Fun
    63Fun Member
    82
    3
    Aug 27, 2012
    Sometimes the harmonic balancer bolt (the washer attached to it) is bigger than the pulley opening (or close to it) and holds the pulley on. I've had that happen.
    Glad you got the pulley off!
  8. 1978 NYB
    1978 NYB Warfighter FCBO Gold Member
    38,977
    10229
    Apr 16, 2011
    Classified
    I took mine off my old engine and it fell off when I unbolted it.
