Samplingman
1970 Chrysler 300 Series Base trim with no vinyl roof | eBay
“74,000 miles. Needs cosmetics and some interior work and carpet. I bought it from South Carolina in 2012 with a seized engine. I bought a '71 300 running parts car and did an engine swap. This is a car you can drive anywhere. I have gone through the car mechanically myself. New radiator,transmission lines, HP manifolds, and complete dual exhaust system. It has electronic ignition. The fuel sending unit, speedometer cable, and tires and brake system. I have invested many hours to save this car. The frame is rock solid. There are some small rust through spots in the trunk area and front floors but very small issues. There is just one place behind the driver's seat in which should have a small section replaced. The blower doesn't work but the car gets heat when you are driving. The dashboard is tacky and the front seat and arm rest should be redone. It also needs a new headliner. There was rust around the front and rear windows which I repaired 2 years ago with Marine Tex. Needs finishing”
