Fireguyfire
I’m just finishing up the engine bay on my 1970 300 convertible after going through the engine, and pulling the generic aftermarket wiring harness the previous owner had installed in the car.
My question is regarding an engine ground strap. Of course the negative battery cable comes off of the top front of the engine, and also has a body to ground wire off of the negative terminal.
I’ve restored a bunch of B and E bodies over the years, and they usually have a ground wire running from the firewall to one of the engine to transmission top bolts.
My engine doesn’t have that, but it could have been easily removed. I’ve been through the FSM and see no reference to a rear engine ground, but I thought I would double check here before I start live testing the wiring.
Should there be a firewall to engine ground strap on my 440?
