70_NPORT
Ok ten four on the rotation I didnt know if that small amount of movement I was feeling was normal.The rotational movement is part of the mechanical advance. As the RPM increases, the weights move outwards and turn the top portion of the distributor shaft/rotor to advance the timing. So what you are feeling is 100% normal.
If you have carbon in the cap, replace it. The carbon can cause all sorts of issues with misfires.
