furyus 67
Stan, do you know any Lightbody's?
Well, its pretty rare to find lead pipes down here, but then infrastructure in the southwest is generally newer than in the north/northeast and the great lakes area anyway. Its semi-big news when a lead pipe is discovered anywhere down here, but it does happen rarely. The state was renovating a big facility here a few years ago and encountered a couple of lead pipes still in use and removed them... it was a fairly big news story.Don't be fooled everybody, if you live in a city that the infrastructure could be considered "old" then there's lead in your pipes. It's a matter of keeping it under control, this could have happened almost anywhere.
I keep forgetting that yo said you were a slow learner.Could, I'll ask him next time I talk to him. He's in the s.boston laborer a union, works for a few crews out that way.
If you look at the waste and vent pipes (probably easiest to see in the attic) and look where two pipes join together with a hub. You'll see that down in the joint it is about a 1" deep lead joint. We pack jute (rope like material) down in that hub until it is about an inch from the top of the hub. Then we pour molten lead to fill the the hub to about an 1/8" below the top of the hub. We than use a special chisel and a hammer to peen the lead against the inside perimeter and outside perimeter which seals against fluid and odor leaks.
Although I am slow learner at times(been drinking flint water for 40yrs) I just can seem to maintain any interest in watching men chase balls of any size or color. I do know who Barry Sanders is tho!;)
Nothing is a big deal in Flint anymore. They've closed 2/3rds of Flints school. There's houses in Flint that's date to the 1800's. Most houses in downtown were built in the early 1900's. Corporations draw hundreds of thousands with promising jobs then pack up and leave the city, not much left for Flint. UofM gets an A for effort. They've brought a great deal to downtown. Still not enough tho.Well, its pretty rare to find lead pipes down here, but then infrastructure in the southwest is generally newer than in the north/northeast and the great lakes area anyway. Its semi-big news when a lead pipe is discovered anywhere down here, but it does happen rarely. The state was renovating a big facility here a few years ago and encountered a couple of lead pipes still in use and removed them... it was a fairly big news story.
Urban water treatment systems do indeed try to keep the water very alkaline to prevent lead from leaching, even from copper and brass lines. But that has a downside, too. Water with a pH over 8 is pretty rough on your skin.
Only meant to post once, my computer was having some technical difficultiesOk, ok, We get it.
That's one theory! Other theories are -dropped on head, ate lead paint or it coulda been the the mercury (my grandpa had in a jar) I used to play with...So Furyus, is that what the water up there has done to you.
Sure their was no Dynamite or C4 involved.That's one theory! Other theories are -dropped on head, ate lead paint or it coulda been the the mercury (my grandpa had in a jar) I used to play with...
