Someone recently went through trouble with the fuel gauge and sending unit and reported on this forum.View attachment 424763 Hi everyone, getting to the end of the restoration on my 65 fury and sorting through some electrical issues. Fuel gauge didn’t work at first but a couple of days ago it started working but shows over full. This morning I jumped in to move car and for the first time it actually read correct at a quater full( it’s only got about 25litres in it).But when I put the car away tonight it’s gone back to reading over full. Anyone have any ideas on this. Regards Terry
The wiring for the fuel sender DOES NOT run thru the bulkhead connector. It runs down the drivers side under the carpet to the trunk.I would check and clean the bulkhead connectors and would also check the ground strap that goes from the fuel tank sending unit to the steel fuel line as corrosion or a broken ground strap can give you erratic readings.
