My intention is to get this drivetrain into a C body next year, but I still need to do a lot of research...any suggestions or links to others that have done this is appreciated.
Yes I can Marko as you know me I even could do the swap as I have the templates that will be needed.im sure @Tobias74 can offer some advice ( if home renos and work/life allows)
Yes you can use some stuff but you still have to do some fabrication to make it work, as most know I’m running an Eagle Hemi in my 70 Fury and I love it even my wife’s drivers that car no problem long distance.A friend of mine will be installing a 5.7 in a '69 Sport Satellite, but he has a lot of heavy rust repair work to do before it's time to mess with the engine. We've had some short conversations so far about installing the 5.7.
Apparently, Holley sells everything you need to put the engine in a B body, making it almost a completely bolt-in affair. I'm sure that some of the B body stuff will work on a C body.
1966-72 Mopar B-Body Gen III Hemi Swap System - Holley
Jeff
