How do I get better gas mileage
shales
I have finished my 67 plymouth fury III. 383 with a complete rebuild about 800 miles on it now , Tourgue Flight Transmission. checked the mileage about 11.5 MPG. It has a edelbrock 1406 , 600 cfm I have few options, rebuild the 600 with small jets, install a edelbrock 500, don't know the number or go back the original which I believe was a Carter, not sure just guessing. any suggestions ? . I have not been breaking it in real easy, not hard either I get on it once in a while which don't help the mileage . I appreciate your views. Thanks
steve
Smaller jets does not get you better mileage. A carburetor properly jetted will get you the best mileage.
Changing carbs will not guaranty that you better mileage. If it does, the old carburetor wasn't working properly and you could have just fixed that carb in the first place.
The choice of cam you put in for the rebuild: Economy or power? Too late now.
11.5 mpg is average for a barge with what I assume has 3.23 gears.
You need to get that engine dialed in correctly first. Timing, vacuum, jetting....
As stated above there's a lot of info missing. What is your tire size? Are you on the highway a lot? When I got the Monaco it had 60 profile 14" tires and the 440 was turning 3300 rpm at 60 mph. Needless to say it burned through a lot of gas. If you are not going to the track just put highway gears in it for leisurely cruising.
This one gets great MPG !!!!!
But no style !!!!!
Good gas mileage in a heavy vehicle is difficult to achieve. Modern v8 1500 series pickups are generally still at or below 25 mpg. My SRT charger barely got 25 mpg highway. That being said, there are ways of eeking out better mileage with any car, without tearing into it too deep. Starting with the engine, getting the most efficient burn is key. As stated earlier in the thread, tuning is everything. The carb must be working optimally for the requirements of the engine. If you are using a Holley and have low engine vacuum you may need to change the power valve to better match the low vacuum signal. The factory power valve needs a good bit of vacuum, something like 12 inches at cruise to stay closed. Otherwise it will be adding fuel to the mix that is not needed. The ignition timing must be right, the spark plugs must be the right range and gap. The ignition system as a whole must be working optimally, good wires, coil & distributer. A clean & free flowing air filter will help, a lot of efficiency can be lost here. Free flowing exhaust will help. You dont necessarily need headers and flowmasters (though they sound cool too) but a clogged exhaust is bad news. Having the right weight oil in the engine will help, go with the thinnest oil possible that does not increase consumption. You must also use the proper gas for the engine. Just because you aren't running a 11:1 race motor doesnt mean you cant benefit from higher octane gas. Carbon build up can cause detonation which is bad all around. You must have the proper air pressure in the tires, mileage is lost from increased drag here. Even things like a 'loose' torque convertor can rob some mileage. Check the brakes as well, even slightly dragging brakes will hurt mileage. Lastly, driving style. It amazes me how many people are on and off the gas unnecessarily while just cruising along. Every time you push the go pedal the accelerator pump in the carb blasts more gas down the manifold. A steady cruise will gain some mileage versus on & off the gas. You probably aren't going to be in the 25 mpg range but making sure everything is tuned correctly could be the difference between 11 mpg and 16 mpg.
Hope this helps!
I never in my life have or ever will buy a car or truck for its fuel economy ,, It's either comfort, speed and or work to make money so to me fuel economy never is part of my equation.
