In car sensor
jmustian
Cartersville VA 23027
Does anyone have experience with an in car sensor. Apparently was on AT1 systems. Two wires are connected to the air tube from the aspirator. It looked like a fragile heat affected wire across the tube and connected to the wires, one on each side. I couldn't find it online yet and part number is 2936048. It seems repairable like a map sensor wire.
Assuming it's the same or similar to AutoTemp II that was in my 77 New Yorker it's a thermistor. The FSM may explain the resistance values it should have at specific temperatures. If you can't find a used one you may be able to source a thermistor with similar characteristics.
I have the one from my 77 (which I converted to non-Auto Temp) and it tested good. But I don't know if they're interchangeable.
I'll check on that. All I have is two leads and no thermistor
