Back in '86 when I was restoring my dad's '67 Monaco (Canadian car with poly 318) we replaced the engine with a re-man engine from a local Chrysler dealer. I've only put about 10k miles on the car since then. At the time, my dad said the new engine gave the car more pep then he ever remembered the original having. The 10k miles that I put on the car all happened in the 10 years after that, basically no miles since about '93 or so, and not driven or started at all between '99 to 2022.
Since about a year ago I've burned about 7 gallons of gas either idling the car or driving it short distances in the city.
After warming it up last night, I took the plugs out and did a compression test. Three cylinders were showing 140 - 142, three were showing 150, two showing 145. Using about 4 cranks for each cylinder, first crank always gives 100 or more PSI.
Then I slapped my forehead after realizing the throttle was closed. I jammed it open and repeated the test on a few cylinders but it only seemed to add 2 to 4 PSI to the numbers - ?
So my questions are - are these numbers ok, and should there be more of a difference between closed throttle vs WOT?
