Question mr. fix it. Your lithotripsy take place in a table or in a big S.S water tank with you sitting in a S.S. "lawn chair" in that tank strapped in so you cant move while they spank the water for the better part of an hour. With that procedure the urologist used to slide a 20" long plastic tube 'bout 20% the size of a #2 pencil with holes in its entire length from the end of your Willie thru your bladder then up the next tube to where that tube joins your kidney and they leave that plastic tube in there for a week to ten days and it's there so IF your plumbing swells up your kidney will continue passing water to your bladder and on out. I'll describe the procedure in removing that tube in the next installment. AW WTH, Ah couple inches of heavy black thread are attached to the end of the tube that's hanging out of you so that your Urologist has something to lace his index finger thru' and tells you to take a deep breath and exhale. The next move iz for you to picture all your plumbing down there as a chain saw and the Doctor iz getting ready to start you. Think that won't blow the wax out of your earz? And trust me guyz, I can not make this stuff up. I waz in that tank 5 times starting about 1980 and had that wax removal treatment 5 times too and once on the table where the medical profession had improved the procedure to a point that they weren't using the plastic tube anymore so no more chain saw treatment, JerI have had this too many times
had the lipotripsy done 2x now
it’s going to be a few weeks before you feel totally better
Wishing you all the best in recovery
