The convertible rear window slides straight down into the rear quarter. It's smaller so it does not need to pivot to fit completely inside the body. Consequently it uses a different mechanism which I'm pretty sure does not use the square sliders, which were the part that was not reproduced until now.I need help just to clarify. I have a power 1/4 window quit this fall. I was going to get into the window this winter. I know I have an issue with the motor or switch hiwever, I have always needed to pull up and push down the windows while using the power switch.
Would I be correct to assume that these rollers will help resolve this problem, on my 66 300?
