bigmoparjeff
Ever start a project that you knew was a mistake right from the beginning, but you did it anyway? Here's one of those projects:
A long time acquaintance of mine is pretty much an expert at destroying vehicles, whether it be by crashes or mechanical abuse. Two of his latest victims have been sitting at my house for at least the last two years after the township made him get them off his property. He was considering junking them, but being a person who can't stand to see things that still have life in them go to waste, I ended up purchasing the pair.
I've done quite a bit of work to both vans since he purchased them. Both are model year 2000, a Town & Country LXi, and Dodge Grand Caravan Sport. Right now I'm working on getting the Dodge back up to snuff. It's been off the road for at least four years now, after he ran it out of oil and spun a bearing. That wasn't too long after I did a total brake job, front and rear, along with a timing chain, oil pan, and a bunch of other work to it. Earlier this year my father's '92 Custom Cruiser was retired due to a rusty frame, so I figured I could get the Dodge into the shop and have it back on the road in fairly short order. I already had an engine and trans sitting in the shop that we got at a u-pull-it a couple years ago, so I ordered up a truckload of parts from Rock Auto that I knew that I would need for the job.
What I didn't plan on was how much the van deteriorated from sitting for four years, two of those parked over grass. This van had been much better than average when it came to rust, and I was quite shocked to see how bad it had gotten from sitting. All the brake parts that had been replaced were now junk and needed to be done again. I'm pretty OCD when it comes to rust, so something was going to have to be done about the mess underneath the van, and now it's become a restoration project.
My father's '94 Town Car is on it's last year due to frame rust, so the Dodge will be replacing that car, and I'm hoping that we can get ten years of mostly trouble free driving out of it. Here we go!
Crusty and rusty front end parts
Rusty in the back too
Brake lines at ABS pump
Rear axle out for clean-up
Not sure how well ABS would work with this much corrosion on tone wheel
Brackets off for blasting
Blasted and painted. Much better!
Rear axle cleaned up
Painted
Painted
