moper
- Joined
- Nov 15, 2010
- Messages
- 810
- Reaction score
- 445
All are in Eastern CT, 06237, town of Columbia. Pictures by request. Can ship world-wide for crating/shipping costs or can drive up to 200 miles for gas/cheeseburger money to meet you.
'65 273 (9/4/64 casting) long block. Stuck fast - no oil pan, valve covers, or rockers included but does includes 2bbl intake, timing cover, balancer, and iron water pump - $50
'70 cast 340 block - numbers not visible (rusted away) - cleaned and magged, 1 bore sleeved years ago, std bore, surface rusty - $400
'67 383 block/crank/ & rods - magged, std bore, all are rusty - $150
'76 400 block - std bore - $300
'74 440 cast crank - haven't measured but should be std/std & looks good, will include balancer - $100
273 mechanical rockers, shafts, and pushrods - $200.00
Slant 6 oil pan - $25
64/65 273 cast iron marine 4bbl intake - $40
Core set of RB "LY" rods - $20
Core set of B wedge rods - $20
late model 360 4bbl modified with W2 bolt pattern - $25
'65 A904 trans core - no cables, with flange output & small input & matching stock convertor - $200
'65 LA Power steering pump & bracket - not frozen but haven't seen it run either - $50
'65 273 B body manifolds - $40
mid 70s 413 - short block - turns with socket, clean, reportedly was a running unit & looks the part - $400.
"516" head castings - bare, magged but rusty - $150
Also can provide complete performance and restoration services by former ASE Master Tech, mild to wild, tune ups to full restorations, references available. Sonic testing available.
