SOLD My 1962 Plymouth Savoy Suburban
72DL41
Michigan
I guess you can only select "Not Mine" as a prefix. Anyway, it's mine and it's also posted on the B-Bodies Only Forum.
  • Originally a slant six, three-speed manual, Sandstone ext., Cocoa int., no radio. Was a Texas car.
  • Now a 440-4 bbl. (rebuilt), A833 four-speed manual with O/D (rebuilt), Pale Jade (Code F) ext., Gray int.
  • Engine: 1973 block, steel crank, std. bore/rods/mains, 452 heads, Comp Cam P/N 21-306-4, Mopar dual-plane RPM intake.
  • Manual steering, manual front disc brakes (Right Stuff kit), rear drums, 8 ¾ diff. (rebuilt), 3.23 gear (non-s/g), dual exhaust.
  • Odometer reads 13,221 mi. (speedo. calibrated and odo. reset to “0”).
  • Purchased in 2016 and completed a two-year project consisting of drive train (replaced K-frame), suspension (front sway bar, bushings, torsion bars, leaf springs, shocks), floor pans (AMD), brake lines, fuel lines (tank cleaned), electrical wiring (Ron Francis kit), heater (aftermarket), 22 in. used radiator, exhaust, paint (MAACO), new windshield, interior (seats rebuilt; door panels recovered), wind lace, weather stripping, seals, gaskets, wheels (15x7), tires (Cooper 225/70; 275/60), vehicle weighed.
  • Recently replaced the carb. (650 AVS2), air cleaner, distributor (with Pertronix), coil (Pertronix), spark plugs (NGK), and upper radiator hose.
  • There are miscellaneous extra parts included.
  • Built as a fun, dependable driver. There are minor imperfections on the body and paint.
  • Clean, clear title in my name. I have a folder of receipts and a zip file with progressive pictures of the project.
  • Contact me via PM for further details. Buyer responsible for transport from 48383.
  • $26,000 or Best Offer (wire transfer).
