At the front of the car?Looks gray in color. If so, given the location, it's the oil sender wire.
1970 Plymouth Fury 3 with 318ci
318 car. Distributor at rear of engine.At the front of the car?
Edit... It's a SB.
Yah, I know...318 car. Distributor at rear of engine.
Responded as you were editing...Yah, I know...
I agree, Oil Sender wire. Ground it, if you have a warning light, it will illuminate. If you have a gauge, it will peg high.
I have a gauge and it works fine now. Are you saying if I ground it, I'll peg the gauge?
I was never planning on grounding that wire. Why ground something if you don't know what it is or what it's for?
I believe the advice to ground the wire was given to the OP.I was never planning on grounding that wire. Why ground something if you don't know what it is or what it's for?
Yeah, buddy this is the first thing I would do.I would take your multimeter and make sure the wire isn't live.
