My three 67 Polaras
Here is the standard Monaco (not mine), equipped with a spear, rocker, and wheel well moldings (which I am pretty sure were all part of the Monaco package):
What is odd about this illustration in the service manual is that the 500 emblem is incorrect. Here it uses the 500 script from the Monaco front fenders, on the rear quarter panel. All of the production Polara 500 convertibles that I have seen use the round 500 emblem on the quarter panel.
Most serviced manual illustrations are of pre production cars so irregularities are not uncommon.
Also, I don't think the side spear was available on any Polara or Monaco 500 models in 67.
Actually my replacement tank from Van's had a thicker locking ring than my original. I found the leaks come from not keeping the locking ring and gasket perfectly centered as you are tightening / locking it. There is not much room for error. You will miss align this about 3 out of every 5 times you remove it. (especially if you are doing it under the car, just ask how I know those numbers)It was possible to order a rocker molding on a spear equipped (non 500) car. In that case it was just a rocker molding, and did not contain wheel well moldings. It is on page 2 of the option sheet. It might show up on the fender tag as j4, but I am not 100% sure because a few of the option codes have not been mapped. It is on the second page of the option sheet under 544. Note the part on the end of that says Polara 318, Polara (the two models it was available to be ordered on). This means the rocker sill molding could not be ordered with the Polara 500 package, simply because the Polara 500 came with its own rocker molding that was integral with wheel well moldings. Nor could it be ordered with a Monaco.
Pictured are the option list sheets and my 383 Polara Sedan. It has the spear, rocker molding, and no wheel well molding. Option codes on the fender tag are j4 (body sill narrow), m3, and w8. Not sure what m3 and w8 are because they did not show up in the decode. Since the car is also equipped with 543 Moldings door upper frame, I would suppose one of those is the upper door moldings.
CAR: Dodge Polara 4 Door Sedan
DL41G79XXXXXX
PLANT: Windsor
ENGINE: 383cid 2-bbl V8
TRANSMISSION: 3-Speed Automatic
TIRES: Unknown tire code
BUILD DATE: November 25.
AXLE: 2.76 Rear Axle Ratio
INTERIOR: Black Interior.
PAINT: Monotone Light Green Metallic Paint.
OTHER: Black Upper Door Frame Color.
MOLDINGS:
ABC OPTIONS:
R1: AM Radio
T8: Unknown Option
X2: Tinted Windshield Only
abc OPTIONS:
h7: Fender or Hood Mounted Turn Signal Indicators
j4: Moulding - Body Sill Narrow
m3: Unknown Option
w8: Unknown Option
The ‘68 number for regular Polara start with 3004402-3. I am very familiar.Yes for 1967; but I don't have the 1968 parts manual.
Item 29.
Nice ride bud im also looking for lower rear fender trim for mine hard to find
Nice ride bud im also looking for lower rear fender trim for mine hard to findView attachment 380241 View attachment 380241
I have 68 Monaco and it has that style of trim - wish it looked half as good as that - its mostly trashed and bent - its coming off and sadly will not be going back on - just hiding a load of rot holes as far as I can see.I have been looking all over for this type of lower body trim also. I found this one and the front fender trim as well, but no more. I am looking to have the rest fabricated new based upon the trim I have obtained. Is this the same type you are looking for or is it the wider, lower trim you want? Beautiful car!!
Maybe if they had six speeds...Gonna sell my Beemer now anybody want one O them
